Re: 450D Day Time to check the Cam Gear!
Posted by Janicholson on October 11, 2007 at 15:01:50 from (66.173.50.9):
In Reply to: Re: 450D Day Time to check the Cam Gear! posted by Brian Jensen on October 11, 2007 at 13:38:16:
Two directions to go:
Looking up into the bottom of the engine is it possible to see the front timing drive gear on the crankshaft snout? and on the left side front of the front cover there is a sheet metal cover with 5 or 6 bolts holding it on there could be some clear sight lines to the cam gear there.
The cork probably came from a valve cover gasket being scraped off, not to worry on it. If you have not removed the starter, do so and try to rotate the engine backwards (look at the fan to see which way)with a stout screwdriver in the flywheel teeth. If it moves at all, check the teeth on the timing gears. Good luck, JimN
