3514 Engine water Pump
Posted by Travis Shuman on October 11, 2007 at 15:18:36 from (12.0.177.36):
I have a IH Industrial 3514 & lost the water pump. Does anyone know what engine was used in this tractor? I was hoping to go right to the engine mfg to get the water pump. If not, does anyone know where I can go to get a new pump?
M/N 3514, S/N 783W, 4 cylinder gas engine. Has a 580 loader, was set up as a back hoe but no longer has the hoe attachment.
Thanks for any info you can provide.
Trav
