Re: 450D Day Time to check the Cam Gear!
Posted by Brownie450 on October 11, 2007 at 18:02:54 from (207.177.82.219):
In Reply to: 450D Day Time to check the Cam Gear! posted by Brian Jensen on October 11, 2007 at 08:45:18:
Just thinking ---have you ruled out the possibility of there being a locked-up bearing in the live power or the input to the transmission? You could try blocking the clutch ahead to isolate the transmission. As to the live PTO, --that is a little harder--would probably require shifting the live power "doodad" for lack of a better term--into neutral. Don't know if all the 450's had that or not. It's on the bottom of the TA case if memory serves me correctly. A bad/ locked-up bearing in back of the clutch/ live power could act like a locked engine.
