Re: Tranny oil mixed with water
Posted by Haas on October 11, 2007 at 18:20:45 from (12.65.30.22):
In Reply to: Tranny oil mixed with water posted by Scott Rukke on October 11, 2007 at 13:17:23:
Some say the water gets in through the bolts or the shifter hole. However, I believe most of it is condensation. When the tractor gets cold in the winter and then a warm spell comes, it will sweat like a glass of iced tea in the summer. Whatever it is, if you work the tractor pretty hard now and then after you get the big batch out by draining, the transmission will get hot and the water will evaporate away. Problem is most of these old tractors don't work much. Also be aware, that if you have water in the transmission, there is also some in the belt pulley gear box. The only way to get that out is to loosen the flange that holds the pulley shaft in place and pull the assembly out and let it drain.
