Re: F-12 F-14
Posted by Andy Motteberg on October 11, 2007 at 18:30:33 from (4.143.220.14):
In Reply to: F-12 F-14 posted by Mike Wielenberg on October 11, 2007 at 18:05:19:
A F-12 has the steering shaft lower down, and The F-14 steering shaft was raised up higher. The F-14 also had a taller seat pole. The F-12 & F-14 use the same engine block, fuel pump, carburetor and magneto, but the F-14 had a different cylinder head, tighter governor spring (for higher RPM). The F-14 also had the crankcase breather in the valve cover and had a 3 bolt air cleaner mount instead of a 2 bolt one. I'm not sure, but I think that the hydraulic lift was a option for the F-12 or F-14. On the F-12's with a dual fuel tank, the small tank was inside the large fuel tank on the F-12's, and the F-14's have the starting tank in the hood.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
