Re: will 460 engine fit in a h or 3xx series?
Posted by ChadS on October 12, 2007 at 17:18:49 from (4.224.78.7):
In Reply to: will 460 engine fit in a h or 3xx series? posted by casered on October 12, 2007 at 16:43:41:
casered said: (quoted from post at 16:43:41 10/12/07) I"ve often wondered and thought it would be neat to repower a 350 or an H with an engine from a 460 and wondered if it could be done. I know engines from 560 and up will fit an M and so on, but never seen it done to a H or 350. I"m am mostly curious if the engine would fit the bellhousing and if the clutch and such would line up? Would the engine even fit heigthwise or would it interfere with the steering shaft?
Just think this would be a neat conversation piece and for parades and such if it could be done. What"s the consensus on this?
It can be done. Should be a swap right out for a 300-350,,, For a H, you have to swap out the starter ring, pilot bearing and clutch disk for it to drop in a H. H thru 460 is the exact same bellhousing bolt pattern. As for frame rails and a front bolster, 460 rails bolt right on the H-350 bellhousing, it takes it out to the same width as the M -560 frame rails, so possibly put on a M front end for overhead steering. I built one up as a 460,,, when it was done, had alot of power, ended up sellin it. ChadS ChadS3@hotmail.com or www.thetractorshop.com
