Re: H starter switch problem
Posted by J in Pa on October 12, 2007 at 20:30:28 from (24.239.59.159):
In Reply to: H starter switch problem posted by C1802362 on October 12, 2007 at 15:27:25:
the problem might not be in the switch.
some of the the lugs, for the brushes in the starter, are soldered. sometimes the solder gets hot and melts and runs out of the connection.
thus hard cranking or no crankingat all.
i had this problem with my H a few years ago.
hope this helps.
good luck.
J in Pa
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
