Re: serial# for M
Posted by Ron in Nebr on October 12, 2007 at 22:50:22 from (66.252.113.6):
In Reply to: Re: serial# for M posted by danny emory on October 12, 2007 at 20:43:59:
8000 foot pistons I think refers to a piston with a higher dome resulting in a higher compression ratio- the 8000 foot meaning the altitude, such as in the mountains, where the thinner air would require the higher comression ratio to bring the HP level back up to be equal with what it would be on a tractor with standard compression ratio at lower altitudes such as the midwest.
