Posted by Janicholson on October 13, 2007 at 06:25:48 from (66.173.50.71):
In Reply to: Re: SUPER M TROUBLES posted by troy8403 on October 12, 2007 at 15:03:23:
The cam grind (lift, duration, overlap,and open close rates, will not affect governor settings. carb adjustment, and governor components are responsible for idle speed (carb) and max speed (governor). The shaving of a head can be taken to maybe .100", but measurements need to be taken to assure it was not milled earlier. The "discovery" of the water jacket, by milling into it, or making components very thin is at ones own risk. If money is no issue, all is possible. Piston dome clearance to both the head, and valves begins to be an issue when reducing the compression space in the search for power. The archives have many posts on checking clearances between piston crowns and head components. Good luck, JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
