Posted by El Toro on October 13, 2007 at 18:49:43 from (205.188.116.73):
In Reply to: Timing an A posted by Soundman on October 13, 2007 at 17:49:30:
You need to remove No1 sparkplug near the radiator and bring No1 piston to TDC on the compression stroke while someone cranks the engine until you feel compression against you thumb. Then drop a large handle screwdriver in the plug hole and watch the screwdriver rise while someone slowly cranks the engine. When the screwdriver quits rising your No1 piston should be at TDC. Both valves on that cylinder should be closed too.
Remove the cap and see where the rotor is pointing if it isn't at the No1 plug tower you need to pull the mag or distributor and rotate the rotor to the No1 plug tower and reinstall. Your rotor rotates CW and your plug wires should be in this firing order. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
