Posted by Smith1000 on October 14, 2007 at 11:44:00 from (70.41.108.94):
A friend of mine bumped a hedge tree with the right front wheel of his 300 Utility tractor. Now the right front wheel does not turn with the steering wheel. Nothing is bent or stripped in the axle or wheel. It seems the right side of the steering gear box is not rotating when the wheel turns. Occasionally, the shaft will move some. It is like there is a gear broken. The left side turns the left wheel normally. The left side works fine.
Is this a big job? Is there any way to fix it without taking it all apart? I am wondering if we can even get the parts. The steering has been sloppy for a very long time. The steering gear box would no longer hold oil. It has been that way for 25 or more years. I think the gearbox was pretty much shot and bumping the tree just stripped a gear. Any other ideas? Thanks.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
