Re: Suggestions for an M rebuild
Posted by Grain Man on October 14, 2007 at 18:27:49 from (72.173.210.58):
In Reply to: Re: Suggestions for an M rebuild posted by BF8690 on June 06, 2007 at 10:41:13:
Can you tell me more on what you did with the cam, head and crank? Similar tractor use it at the farm as well pull as much as possible!
Thanks,
