Re: Unknown pump maker
Posted by D Slater on October 15, 2007 at 09:31:57 from (72.65.147.160):
In Reply to: Unknown pump maker posted by Wayne in MN on October 14, 2007 at 18:59:13:
Its Eaton pump like charr Lynn power steering kits used,also used by other manufactures and most look alike although some have differences.
Front crankshaft pulley is stock with pump drive pulley held on by hand starter driven pin in crank. Also with kit is fan spacers and bolts with sleeves instead of stock pins to drive water pump impeller.Fan is spaced forward to clear.
