Re: 1941 A industrial front axle and steering problem
Posted by Ed Fisher on October 15, 2007 at 17:08:15 from (75.134.214.176):
In Reply to: 1941 A industrial front axle and steering problem posted by Jeremy B on October 15, 2007 at 11:03:57:
Jeremy, the "brace" that extends from the axle pivot to the bellhousing is actually the pivot pin. Lift and safely support the tractor so as to remove the weight from the axle. Loosen the clamps on the axle pivot, unbolt the brace from the bellhousing and rotate it away from the housing and slide it out. Good luck!!
