Re: 1206 TA
Posted by Kevin Meier on October 15, 2007 at 19:45:22 from (64.71.85.247):
In Reply to: Re: 1206 TA posted by dwag on October 15, 2007 at 18:43:09:
Calibrate the sprag? What is that? My t/a"s come with endplay intstuctions and t/a installation tips but tractor vet is correct, you just don"t drop in a t/a and put the tractor back together. Make it worth the time and money to be sure that everything is right. Not to mention all of the gear, shafts and direct drive or quill end inspections.
