Sounds like you got plenty of advice. I would put a little WD-40 in there, let it soak a while then use a drill bit just a bit smaller than the hole. It helps to have some old crappy bits for this kinda work. then I just drill it out by hand, or use a cordless drill. Once the dirt is out then run a tap in it, take an air hose and blow it out. Then a little oil or grease and you are good to go.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
