Repair Cracked Cub Bolster
Posted by Wayne Mo on October 16, 2007 at 20:46:59 from (207.69.137.6):
I have a cub with the common freeze cracked front bolster. The crack is across the front and has been previously repaired with epoxy but now leaks slightly in a couple pin point places. What is the best way to repair this?
I imagine grinding out the old epoxy repair and possibly renewing the epoxy repair. Is this ok and what material should I use.
How about taking it to a welder and having them run a bead across the crack which would take a bead about 8 inches long. Can this be done and is it better than epoxy repair?
I am sure this has been looked into by many folks on this board. What is the consensus on repair options?
