Posted by Steven f/AZ on October 17, 2007 at 10:55:20 from (216.67.213.217):
In Reply to: Tight Tire Bolts posted by WonderingAl on October 17, 2007 at 10:16:11:
Use PB Blaster, Kroil, or other good "penetrating" oil. Do not use a "lubricant" spray like WD-40.
I have personally had excellent luck using PB Blaster and the CNH penetrant spray.
Then use an impact wrench - the vibrations/impacts help break the rust loose instead of twisting the bolts off. If that doesn"t work, break out the fire wrench and heat them up... if that doesn"t work, push the lever on the fire wrench and annihilate them! LOL
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
