Posted by glennster on October 17, 2007 at 14:04:34 from (76.224.26.7):
In Reply to: Tight Tire Bolts posted by WonderingAl on October 17, 2007 at 10:16:11:
like steven said use a penetrating oil. i like pb blaster, any autoparts store sells it. if there is paint on the threads sealing the nut, wire brush some off so the oil can creep in there. if you dont have acess to a cutting torch or impact, try a propane torch and just warm the nuts up some. this will cause them to expand, then spray em up. if i remember, the h uses a 7/8 or 15/16 nut. see if you can buy or borrow a 3/4 drive breaker bar and a socket. get the breaker bar on the nut and rock it back and forth just enough to get it to move, then spray it up some more. you should be able to get them off then. run the nuts almost all the way out, then get the wedges loose. be careful if the tire is loaded with chloride and water, its real heavy,maybe 5-600 lbs. you may have to let the nuts soak for a day or two. chase the threads with a die before you put em back on, i dab a little anti seize on the threads too.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
