Re: Rear Axle Size
Posted by Athol Carr on October 17, 2007 at 14:38:06 from (219.89.236.200):
In Reply to: Rear Axle Size posted by Harold H on October 16, 2007 at 17:37:37:
I doubt it. The 10-20 has two nuts on the end of the axle to retain the wheel whilst on the W-4 the axle finishes near flush with the outside of the wheel and there is a retainer plate with a cap-screw into the centre of the axle end.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
