Re: Where does voltage regulator mount on a '48 Super A
Posted by Gene-AL on October 17, 2007 at 17:19:50 from (74.242.20.239):
In Reply to: Re: Where does voltage regulator mount on a '48 Super A posted by SteveNH on October 17, 2007 at 13:53:21:
Steve,
The generator mount (lower left) in Keith-OR's first picture is the correct mount, but as he said, it is missing the 1" bar welded on in the center (you can see where it was welded on). A bar like it with 2-threaded holes to match the VR mounting holes is in the 2nd picture. In my original reply, I didn't remember about the 1" bar, and didn't have my tractor nearby to look. I had recently had my generator and VR off.
Be sure your voltage regulator metal frame is grounded to the tractor frame. Some regulators had rubber anti-vibration mounts and a separate grounding braid/wire which attached under one of the VR mounting bolts. Without a VR ground, the generator won't work.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
