Re: Where does voltage regulator mount on a '48 Super A
Posted by ScottyHOMEy on October 17, 2007 at 18:07:44 from (71.241.212.142):
In Reply to: Re: Where does voltage regulator mount on a '48 Super A posted by SteveNH on October 17, 2007 at 16:11:20:
Steve, does your engine have a water pump?
That arm shown i the picture is for anengine with a water pump, and mounts on the engine end a the front of the pump under the nut nearest the generator.
If you dont' have a water pump, the original bracket was straight and mounted onto a stud through the hole in the water inlet furthest away from the genny, i.e., the inlet was held down on by two bolts into the block. The third hold-down was a stud, where the first nut held the inlet to the block. Above that, the generator arm, which was held down by another nut and lock washer.
I said staight arm. That would be true looking at the flat side of it, but looking at the edge it had a crook so that it could offset around the inlet elbow. The one in the picture is flat, and that might explain the out-of-parallel you describe.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
