Re: 460 Hi-Utility
Posted by Butch WI on October 17, 2007 at 18:37:51 from (69.19.14.30):
In Reply to: 460 Hi-Utility posted by jk on October 17, 2007 at 17:07:38:
jk,
I paid $2800 for a `58 460 utility needed hyd pump fh worn out also steered hard turned out to be lack of lube in the spindles. some cosmetic issues...but it was a utility, not a Hi utility,
Butch
