Re: GOOD CATCH!
Posted by Wardner on October 17, 2007 at 20:42:08 from (4.154.247.96):
In Reply to: GOOD CATCH! posted by ScottyHOMEy on October 17, 2007 at 17:52:51:
You have to be a total Tyro Pyro to blow a hole in a rim or tire while cutting lug bolts. And even if you did do that, there would not be an explosion.
The initial rush of air from the first small penetration should be enough warning to let the torch operator know he had screwed up. There would not be a progressive chain of event that would lead to a catastrophe.
Let's get real, people.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
