Re: Re: Re: Replacing the generator belt
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on February 20, 2000 at 05:11:49 from (12.75.221.37):
In Reply to: Re: Re: Replacing the generator belt posted by Zeke on February 19, 2000 at 16:18:26:
Zeke not the easiest of jobs but doable. You will have to remove the main fan belt from the lower pulley. Then slide the new belt around the hanging main fan belt, and then over the fan blades and you will have it on the back pulley.
Before you slide the belt onto the generator pulley itself, you might want to back out the adjusting screw and loosen up the pulley half to make it wider. Then slide the belt onto the generator and tighten the pulley until the belt is reasonably tight. Don't tighten too tight or you will be putting a strain on the generator shaft bushing.
Post A Followup
: Re: Re: Re: Re: Replacing the generator belt
