Re: cub problem. HELP!!!!!
Posted by El Toro on October 18, 2007 at 17:34:18 from (64.12.116.73):
In Reply to: Re: cub problem. HELP!!!!! posted by russ hamm on October 18, 2007 at 15:53:06:
Are the plug wires in this firing order?
2-1
4-3
When you hold your hand over the throat of the carb your hand should become wet with gas. This should pull the atomized fuel into the combustion
chambers too. You need good intake manifold vacuum to do this. Run a compression check on the engine.
When cars and trucks used mechanical fuel pumps we used that procedure to see if the fuel pumps were bad. You could actually start them as long as you kept that carb covered. Hal
