Re: Mowers
Posted by Lee in Iowa on October 18, 2007 at 20:49:51 from (66.172.198.3):
In Reply to: Mowers posted by Andy Schuppert RN on October 18, 2007 at 15:57:40:
The sickle mowers already mentioned IH balance head, JD #5 work good on an M. The JD 8 and 38 would probably also work good, just harder to mount. Any pull type rotary mower that's not too big would also work just be sure to use an overrunning clutch on your pto shaft. Just google pull type rotary mower or pull type bush hog. Lee
