Re: Farmall H Gas collecting in Carb/Air-Intake Junction??
Posted by old on October 18, 2007 at 21:33:34 from (4.244.6.39):
In Reply to: Farmall H Gas collecting in Carb/Air-Intake Junction?? posted by WonderingAl on October 18, 2007 at 20:37:52:
Choking it to much will cause that and or a bad float or needle seat. Or maybe the float is sticking which will also cause that problem
