The advice below should solve the flooding problem.
However you also need to clean out the weep hole at the bottom of the carb air inlet. It's provided so the air inlet passage doesn't become filled with gas should the carb flood.
The weep hole is protected by a tiny felt filter "button" that's no doubt plugged solid too.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
