Posted by Janicholson on October 19, 2007 at 14:56:29 from (66.173.50.89):
In Reply to: 6 volt gen. posted by tennhillbilly on October 19, 2007 at 14:44:25:
From a good electronics shop, (or the web) get a 3 ohm 60W resistor. It will be pretty big, and ceramic wire wound. This can be wired in in place of the original. Another source is the blower resistors found in the heater motor speed circuits in all older cars. The resistor block has (usually) three resistors. One of these approximates 3 ohms. These must be crimped into place, not soldered (like the ceramic one) They all get hot, they should be located to avoid interference with plastic wire insulation, and grounds. Good luck, JimN
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
