Re: oil and grease for H and M tractors
Posted by Nebraska Kirk on October 19, 2007 at 17:08:27 from (207.91.30.48):
In Reply to: oil and grease for H and M tractors posted by J E on October 19, 2007 at 16:39:31:
Use hydraulic oil for the hydraulics, both the H and the M use 6 quarts. For the trannismission you can use 80/90 weight gear oil or 140 weight gear oil. You would probably want to use the heaver oil to minimize leakage and also the 55-68 year old gears will run quieter with the heaver oil. The M holds 13 gallons and the H, 6 gallons.
