The gas/diesel lever is up for gas and down for diesel.
The turning knob that goes to the carb is the gas throttle. Left is slow -- right is faster. There is also a choke knob that is push/pull.
If you think all systems are go with the gas side, go for it. If everything is functioning correctly, it should start within a couple of seconds. If it won't start on gas, pull start it in diesel. After it is warm, switch to gas and see if it will run. If it doesn't run at that point you can probably determine whether you have a gas or ignition problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
