Re: voltage at alternator reading
Posted by El Toro on October 20, 2007 at 17:34:37 from (205.188.116.73):
In Reply to: voltage at alternator reading posted by keith smith on October 20, 2007 at 13:42:33:
You should check the battery electrolyte in each battery cell and compare the readings. They should be close to one another. They should read
1.250 or better. You may need a diode in that hookup if you're having a problem with battery drain. Hal
