Re: racing idle on M
Posted by Janicholson on October 20, 2007 at 18:00:16 from (66.173.50.72):
In Reply to: racing idle on M posted by e-manhunt on October 20, 2007 at 17:48:37:
Do not run it.
There is a little tang in the joint between the carb and the shaft from the governor (where it bolts on to the carb. That tang fits between two metal fingers. It is tricky to get in to place, but that is your problem. Take it apart at the connection and re fit the tab. JimN
