Re: oil filler cap
Posted by Janicholson on October 20, 2007 at 18:21:13 from (66.173.50.72):
In Reply to: oil filler cap posted by Mike CA on October 20, 2007 at 18:12:21:
The cap (with the two wings on it for your fingers) is supposed to be hand tight. It often got tighter from temp change, and required an adjustable wrench to loosen it. We were casual, and just put the wrench on one of the "wings" If I were you, I would use two wrenches, one on each wing. It should come loose easily. Do not hit it with a hammer. If it still refuses, use a brass punch to shock it at the base of the wing, where it flattens out into the cap. Lefty Loosy. JimN
