Re: voltage at alternator reading
Posted by Bob M on October 20, 2007 at 18:33:25 from (66.66.87.84):
In Reply to: voltage at alternator reading posted by keith smith on October 20, 2007 at 13:42:33:
Keith - With the ignition switch "off" you should read battery voltage at both the BAT and #2 terminals, and 0 volts at the #1 terminal. (All readings to ground...)
You should also get the same readings with the ign switch "on" and the engine not running.
With the engine running (alternator charging) you should get 14.0 to 14.5 volts at the BAT and #2, and 11 - 12 volts or so at #1.
As other suggest, with the engine running many digital voltmeters read incorrectly on account of system "noise" - an old analog meter is the preferred tool here...
