Re: 450-560 Fast Hitch Depth Stop
Posted by D Slater on October 20, 2007 at 19:43:11 from (71.188.208.230):
In Reply to: 450-560 Fast Hitch Depth Stop posted by Brian Schmidt on October 20, 2007 at 17:32:17:
Be hard to make without using a actual rod for a pattern. End of rod that contacts flaper over pin in cylinder is a seperate part held to rod by a small pin. You also need to have the correct pin that connects cylinder rod to upper 2 point lift arms. It has a hole for rod to pass through and hollow inside for spring and metal piece to lock in notches of stop rod. Not all 560 used a hydraulic cylinder with flaper and stop pin and upper cylinder pin wasn't the same as a stop rod type. I could try a picture tomorrow if you still need one.
