Oil pressure is dependent on bearing clearances/tolerances - rings and sleeves are for compression.
Your explanation of oil pressure is useless for a diagnosis of a problem. Get a mechanical gauge that reads in pounds.
An H only needs about 20 psi of oil pressure at full throttle to be reliable. Factory spec for the relief valve is 75 psi, but they will run many many years at 20 psi.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
