Re: Leaking 'M' carb.
Posted by Hayfarmer on October 21, 2007 at 10:01:44 from (66.243.241.35):
In Reply to: Leaking 'M' carb. posted by farmerjoe on October 21, 2007 at 08:49:43:
A couple possibilities. The float may be set at the wrong height or it may be binding up on the casting of the carb. I have gotten several kits and found that the needle and seat supplied are not always right or at least not what ws in the carb. If the needle and seat are leaking generally gas comes out the bottom of the carb, there is a felt seal there for that purpose. maybe someone has pluged that hole so it runs out the ari intake or the hose on the intake isn't tight. The suggestion of turning fuel off is good but if the needle and seat and float are right you shouldn't have to do it.
