Posted by Janicholson on October 21, 2007 at 14:27:37 from (66.173.50.13):
In Reply to: Stepped head pistons? posted by FarmallsForever in IN on October 21, 2007 at 14:13:41:
Well there are no "O"rings on the sleeves. The tractor has dry sleeves in a cast bore. There are possible head cracks that do not affect combustion chamber leakage. As you noted, a head gasket would also do it. Block cracks in the skirt area of the block are less common. Cracked cylinder bores with a loose sleeve (or pinholes in the sleeve) can also leak. If it were mine, I would put three heaping teaspoonfuls of fine ground black pepper (yes that is what I said) into the radiator, and give it a week of operation to see if I could stop the leak. If not I would pressurize the cooling system to 7psi MAX. and with the pan and valve cover off, I would look for leaks. Step head pistons will work without any concern at all. Best of luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
