Re: hydraulic pump Super A
Posted by CNKS on October 21, 2007 at 17:01:40 from (216.144.104.128):
In Reply to: hydraulic pump Super A posted by Robert Ba on October 21, 2007 at 13:55:43:
Fix the unit under the gas tank first, if that doesn't work then that only leaves the pump. Try 30W oil instead of Hytran, I wouldn't go any heavier than that. Before either Touch Control fluid or the later HyTran were available, IH recommended 10W. It could also be something as simple as a plugged screen, drain the block and look at it.
