brake seal replacement on Farmall H
Posted by William Stubbs on October 21, 2007 at 20:27:36 from (208.106.21.232):
Does anyone have some advice on pulling the part that holds the seal (PN 8518)? I used 2 of the mounting capscrews as jackscrews and have broken the casting. I would like to know the correct procedure to pull this part and, also, I need a replacement part since I broke mine. This part is referred to as the "Bull Pinion Shaft Bearing Cage with Oil Seal."
Thanks,
Bill Stubbs bgstubbs@sonic.net Northern CA
