Re: What's this blue goo on my H?
Posted by JT on October 22, 2007 at 07:52:50 from (70.226.202.124):
In Reply to: What's this blue goo on my H? posted by Mike CA on October 21, 2007 at 19:52:05:
go to your local auto parts store, get gasket material, set in on the part you need a gasket for, take a SMALL ball been hammer, tap around the edges of the where the gaskets goes, real lightly, the raws edges of the steel will cut the gasket material, then take a leather punch to make bolt holes, or you can also tap them with the hammer and they will cut the holes out also. I make gaskets all the time this way if the part is good heavy steel or cast iron.
