Re: What's this blue goo on my H?
Posted by GeneMO on October 22, 2007 at 11:38:36 from (207.254.246.53):
In Reply to: Re: What's this blue goo on my H? posted by Mike CA on October 22, 2007 at 11:23:01:
To get the kids started you can use masking tape or scotch to hold the material in place. Then you develop sort of a touch to the "tapping" process. you tap on the gasket mateial just enough to cause the underlying metal to cut the gasket paper, but no more. Same with the bolt holes. if you dont tap hard enough it is easy to give it another light lick, you just dont want to damage anything underneath. Oh, this probably will not work on cork. Too thick.
Good luck, Gene
