Re: Should I...
Posted by Steven f/AZ on October 22, 2007 at 11:51:00 from (216.67.213.217):
In Reply to: Should I... posted by Mike CA on October 22, 2007 at 09:35:35:
You should be able to lock the tires on gravel and slide them... there shouldn"t be any squealing or oil leaking around the covers.
If you have all that covered, don"t bother taking them apart.
