Posted by KEB on October 22, 2007 at 13:41:50 from (192.91.171.36):
In Reply to: Gasket material? posted by Mike CA on October 22, 2007 at 07:56:49:
Thin gaskets without much give (like paper or composite) are used where you have smooth, solid mating surfaces. Thick gaskets with a lot of give (like cork or soft rubber) are used where one or both sides of the mating surface can flex, such as a valve cover or engine side cover. Thin hard gaskets, or a material with a known amount of compressibility are used where a dimension has to be maintained across the gasket joint. A head gasket would be a good example here.
Your bolster would use a thin paper or composite gasket as it has machined mating surfaces.
RTV gasket maker is good stuff, but don't get carried away with it. More is not better, especially when it oozes out on the inside and a chunk breaks free.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
