Re: Should I...
Posted by CNKS on October 22, 2007 at 18:00:17 from (216.144.104.128):
In Reply to: Should I... posted by Mike CA on October 22, 2007 at 09:35:35:
If you are doing what you call a restoration, and it is indeed a show tractor, pull them off, and replace the seals and bands unless the bands show little wear. Sooner or later the seals are going to leak, it is inevitable. Maybe the first time you show it.
