Re: doing research
Posted by Wardner on October 22, 2007 at 19:34:48 from (4.154.245.218):
In Reply to: doing research posted by Pat-CT on October 22, 2007 at 17:54:27:
The guts of all the mechanical TA's are the same. The differences between some models is limited to the output shaft, rear bearing, bearing cage, and seal. There is no difference between a 300 and 350 TA.
I took a NOS TA labeled for a 330 and swapped out those parts for the old SMTA parts and it works fine in the bigger tractor. The TA doesn't care if it is installed in a 30hp or 80hp tractor provided both tractors are driven by the same operator.
