Re: O12 fuel pump
Posted by Athol Carr on October 22, 2007 at 21:28:31 from (219.89.239.126):
In Reply to: O12 fuel pump posted by JeffinWa on October 22, 2007 at 19:40:07:
I have an O-12 that I restored about 7 years ago. The fuel pump should pump enough that you can hear the gasoline flowing back to the top of the front of the fuel tank which is where nearly all of it goes, some takes the T connection to the carburettor which is a bit of a problem if the tractor has been sitting a while as it takes a lot of cranking to get the carburettor bowl full with fuel before it even thinks of starting. The modern fuels don't help as they seem to lose all the important volatiles if the tractor has sate for some weeks.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
