Posted by moseed on October 23, 2007 at 04:31:36 from (208.54.95.157):
In Reply to: O12 fuel pump posted by JeffinWa on October 22, 2007 at 19:40:07:
[quote="JeffinWa"](quoted from post at 19:40:07 10/22/07) I purchased an O12 that has not been running for 8 years. First thing I noticed was no gas in the tank or the filter bowl. When I put some in, after cleaning the bowl, the pump would not. When I took the pump apart the diaphram was too stiff to move. I flexed its edges and gradually got it to be a little more pliable. Now it moves a little air, kind of a snorting sound, when I push on the pump lever where the rod from the block whould normally push on. When I bolt it back on the block a few drops of gas do come out the output which is better than the nothing before. Still not much better though. Anyone have any hints about this or an idea where I can get a replacement diaphram or whole pump? After that I have to see why she's not sparking. But I haven't peeked at the points yet. Thanks in advance for the help![/quote
There are at least two diaphram scenarios in that fuel pump. It has been too long since I had one of those apart but one has the diaphram that comes out separatley and the other is a component part, I think it is attached to the plunger and conot be separated from it. Discribe yours to Gordon and he will set you up I am sure.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
